Old 15-07-2015, 11:07 AM
1BadAzzWS6 1BadAzzWS6 is offline
Question Need help with wiring for 1998 Trans Am
I'm just wrapping up the HFS-3 v3 install on my 1998 Trans Am. I connected the grey ECU harness (Injector + wire) to the blue PCM connector pin 19 and the (Injector -) to the red PCM connector pin 33. When I turn the system on to check the wiring/electrical, I am not seeing any green LED's on the dash gauge, so it's not seeing/detecting the F-IDC. Do I have this connected correctly? Should I be using the blue MAP sensor wire an connecting that to the PCM as well? Do I need to use the green harness to connect to the injectors instead?
Thanks for the help!
Zack
Old 15-07-2015, 01:53 PM
Default Re: Need help with wiring for 1998 Trans Am
The green led is not on the dash gauge. You need to open up the controller box. There is a green led there.
Old 16-07-2015, 09:15 AM
Success! I didn't realize I needed to open the controller. I went out and confirmed the green LED is flashing in rhythm with my engine speed. Thanks for your help. Now on to the mechanical testing and priming/purging.
Thanks for your help!
Zack
Old 16-07-2015, 10:27 PM
Good news!
Old 11-08-2015, 09:10 AM
Hi again Richard.
So I'm at the tail end of my installation (been on hold for a bit while I was installing the rest of my supercharger setup). Everything is hooked up and working and I'm at the part where I need to install the jets into my intake tube. I chose 3 jets with my order, but my system only came with one "T". Should I have ordered a second "T" fitting or one of the distribution manifolds to connect the 3rd jet? Also should the jets be installed before or after the Intake Air Temp sensor?
