Old 09-03-2015, 04:06 PM
HYDE16 HYDE16 is offline
Default Re: Injecting prior to turbo comp' impellers
Ok I'll take a look without the pre-turbo jet then with.
Old 09-03-2015, 05:37 PM
Is the weather still cold in New Jersey?
Old 09-03-2015, 06:15 PM
Not today, a beautiful sunny 45 degree day. This thread got me pumped up to finish the install, just mounted the tank and pump, connected the level sensor connector, fluid lines and pump connector. Moved the jumper to DHB and turned the gauge on, the entire system is alive again! Time to go out for a ride a little later today!
Old 29-03-2015, 01:14 PM
jmlegacy jmlegacy is offline
Found this dyno at this location
A 315 cc nozzle pre turbo and a 130 cc nozzle post ic. Nothing else was done.
His spool was later, but his torque extended more. Is this the SHIFT of the compressor map that is talked about?
Old 29-03-2015, 06:48 PM
If anything, the nozzles position should be reversed. Also to make it a fair comparison, we would need more data like boost pressure to even make a call...
Old 30-03-2015, 12:22 AM
Man I can't wait to get on the dyno and even run some data logs around my .3mm pre-turbo setup. Just got a new clutch installed, need to break it in before I can really run 3rd gear full throttle logs. 450 miles to go.
Old 31-03-2015, 09:55 AM
parmas parmas is offline
On his website there is the Pre-Turbo-WI-Dyno-Test.zip attachment. In it there are .txt files that contain all data.
I sorted out the data into an excel file and removed the insignificant data.
Between 4250RPM and 5250RPM Post turbo map had more boost compared to Pre-Turbo and continues like that till redline but after 5250RPM PRE-Turbo makes more power and torque
Could be turbo efficiency ?
File Type: zip Water Injection Dyno Post_PRE_RX7CLUB.zip (25.1 KB, 4 views)
Old 03-04-2015, 09:31 AM
rotrex rotrex is offline
so, just activate injection past 5200 rpm...
I found .3mm pr compressor (Rotrex) having little effect.
.7 mm worked well.
I use 4x 0.3mm direct port now.
In genera found the more water methanol I injected the more power I was able to extract.
Sweet spot seem to be around 300 ml/min for my engine flowing about 1.5l of fuel per minute. injecting more adds not enough to justify the extra consumption.
Old 03-04-2015, 02:04 PM
I'll be testing a .3mm jet post MAF (3 feed from turbo compressor), boost activated at 5psi.
Old 14-04-2015, 08:42 PM
That's my thinking too. I'm actually thinking of doing a two stage with a ~50cc nozzle pre turbo @4psi and second stage @18psi (190cc).
Maybe 50cc not enough? I just need it to help me launch my autobox better.
