Old 12-11-2014, 07:39 AM
Racing Station Racing Station is offline
Default How can tech me use hfs4-v2
I use HFS-4V2 I use MAP3,1.0 jet,0.7 restrictor working now,I 1min I get 375cc on sys
But I want get 1min 500cc ,How can I do it?
SC 70%
please teach me
Old 12-11-2014, 09:01 AM
Default Re: How can tech me use hfs4-v2
Remove the restrictor and re-test. Let me know the result. Also set the PI-R to Fully clockwise.
Old 13-11-2014, 04:34 AM
I try it !
But get 350cc on sc 70% I use Aquamist Check Valve Jet!
I try other, have not Check Valve Jet, I can get 400CC
So ~
How can I do?
Old 13-11-2014, 09:10 AM
You can also increase the pump pressure (1/16" allen screw at front end of the pump head) to 180-190psi. (about 1/2 turn clockwise).
Old 13-11-2014, 09:16 AM
So I can use 1.0 Check Valve Jet!
Use You said method?
If 1.0 Check Valve Jet on 180-190psi pump I can get how much cc?
Old 13-11-2014, 09:49 AM
I would check the flow curve on the user manual. Take 15psi off for CVJ.
So.. what is the flow rate of the 1mm jet without the restrictor?
Old 13-11-2014, 10:52 AM
I don't use restrictor
Old 13-11-2014, 12:58 PM
Now or before? I read your first post on a 0.7mm restrictor.
Old 13-11-2014, 01:10 PM
Before use 0.7 restrctor!
Now have no't use!
Old 13-11-2014, 01:43 PM
OK. Thank you. Very clear now.
