Old 06-10-2017, 06:45 PM
valentinp valentinp is offline
Default Hfs4 v3 N54 - wgdc cut in half after switching to 3.5 bar option
I used the system for years with IDC based injection.
I have the N20 sensor, which is 3.5bar, and no boost controller or piggyback.
I cut the link for 2.5 bar from the board, and solder linked the 3.5 bar option from the back of the board.
I moved the jumper from IDC to MPS and turned the PI R to fully counterclockwise to work based on boost only.
Now the turbos don t spool correctly anymore.
At the begining of the pull, where the commanded WGDC is 100%, the measured value is 50%. At some point the meth kicks in and shows good flow, but if i let it run till redline i get a boost code. Instead of spooling to 30psi, i barely reaches 20psi.
THRES and GAIN are set to 12 o’clock.
No boost leak, and turbos are fine, as i moved the jumper from DHB to DFS to disable failsafe and the turbos work perfect and i also get meth to flow well.
What should i check? What can it be?
Thanks,
Valy
Old 07-10-2017, 01:13 PM
Default Re: Hfs4 v3 N54 - wgdc cut in half after switching to 3.5 bar option
it appeared the failsafe has tripped. You need to dial in the failsafe again a you have changed the configurations. try setting the SC to 10am.
Old 15-11-2017, 01:51 PM
dubversion dubversion is offline
Why cut the 2.5 bar link ? I think by default it's set to 3.5 bar.
