Old 09-06-2013, 08:21 PM
Default Re: Mazdaspeed 6 (update: 8th July 2012 ) SN #12091 onwards
Thanks for the update. One more question, how many 0.7mm jets are you running?
It appeared you are injecting too much, putting out the spark or burn rate is slow. I
Old 10-06-2013, 04:58 PM
Presss Presss is offline
I'm use 1 jet of 0.7mm
Old 10-06-2013, 05:41 PM
It is interesting a 0.7mm jet will affect your engine so much. Can you try running 80% methanol. This test will identify if the previous 50/50 was loading the ignition system.
Where is your jet installed?
Old 11-06-2013, 08:19 PM
my jet install about 25-30 cm in pipe before throttle.
Ok, I try 80% methanol and what I must to see on dash?
Old 13-06-2013, 11:14 PM
How far is the exit of the intercooler to the throttle?
If you are not getting good even distribution to the cylinders, it could cause poor bad burn on one of the cylinders. Is it possible to move the jet further away from the throttle?
Old 15-06-2013, 01:30 PM
do you think this is due to poor spray water methanol mix?
I watch the knock retard and it is not.
Old 16-06-2013, 10:04 PM
I really don't know. sol we shall approach this one step at a time. Can you send a picture of the nozzle installation.
Old 18-06-2013, 08:25 PM
please photo
Richard please say something...(((
Old 19-07-2014, 12:25 PM
Taz1231 Taz1231 is offline
I've just installed one of these kits the question is do you need to wire in the user as the kit was supplied with it, it's a hfs4-v3
Old 21-07-2014, 09:06 PM
You can follow this drawing:
http://www.aquamist.co.uk/vbulletin/...ead.php?t=2188
