Old 31-01-2017, 12:25 AM
Default Re: Aquamist 3 issues
Which wiring diagram?
Old 01-02-2017, 07:13 PM
Nicknacke36 Nicknacke36 is offline
This is the wiring diagram I used.. I wired the two cables into the fuel injector, the green IDC light flashes inside the control unit. But not on the guage...
I don't know if the photo uploaded properly so here's the link where I found the wiring diagram: http://www.aquamist.co.uk/HFS3/manual/HFS3-v3.0w.pdf
File Type: jpg IMG_2577.jpg (157 Bytes, 12 views)
Old 01-02-2017, 08:49 PM
The diagram is used for a conventional fuel injection system, but it doesn't appear to work on your car so I suggest a few alternatives.
If you carry out my suggestion above, we will move forward.
Old 04-02-2017, 04:59 PM
Right, ��
I've moved the red lead to a pre-crank 12v+ and the relay clicking has now gone away! Thanks for the advice!
However I'm still not getting any red bars on the guage for idle/amount of water being pumped in..
When I rev it, I get the B light flashes then go out as the revs drop back down..
I'm still stuck how to fix this :/
I have the green wire from the grey harness wired into the brown/white lead off the fuel injector. The engine is an M52..
Last edited by Nicknacke36; 04-02-2017 at 05:01 PM. Reason: Wanted to add something...
Old 04-02-2017, 05:03 PM
Right, 😊
The green wire from the grey harness is wired into the Brown/white lead off of the fuel injector. The engine is an M52 if that helps.
I have also noticed some minor corrosion to one of the 3 pins on the black FAV assembly that plugs into the valve..
Tags
aquamist, hfs-3 issues, no bars, water level sensor
