Old 24-06-2005, 09:32 PM
2k2SilverBullet 2k2SilverBullet is offline
Default Ford Mustang GT w/ Paxton 1000RR + CoolingMist W/I
I recently purchased a CoolingMist Deluxe Single Stage Performance Package.
I opted to go with a 150PSI Sur-Flow pump and 3GPH nozzle. Should atomized the water nicely.
My question is I will be running water only, mainly to supress detonation/pinging as a safety device. I have a program that adjusts itself on timing via Air Temp, so my tune wouldnt need re-tuning if water is used. However I have thought about using a 15% meth mix so my crappy 91 octane ( I wish i was living in Hungary still 101 octane) to about 95 octane or so....just a small hint of extra fuel.
My question is what do you think about my setup? and if that 15/85 mix is a good idea or just stay 100% water? Have you guys had any trouble with injecting water or any mixtures, like adverse effects
I have received nothing but great service from David Hill, and his parts are top notch....but i would like to know what you guys think.
2002 4.6L Mustang GT
Paxton 1000RR 8-10PSI
Long Tube Headers
Catted Hi-Flow H-Pipe w/ Spintech Catback
42 lb/hr Injectors
Upgrade Fuel Pump
SCT chip tune
http://coolingmist.com/detailpage.aspx?pid=02P
02 GT w/ Paxton 1000
Old 27-06-2005, 02:50 AM
also would it be bad to spray before the supercharger or after the supercharger
Old 28-06-2005, 09:48 PM
If you are running less 10% of water to fuel, it doesn't normally needs a retune.
Old 02-07-2005, 06:17 PM
would a 10% mix of methanol (HEET) would make any difference as far as fuel. all i got here is 91 octane and im trying to get about 93-95 octane yield
Old 05-07-2005, 10:50 PM
I believe, you need to add 5% methanol to fuel to gain, hereis some info.
http://www.aquamist.co.uk/rescr/faq/additive.html
Old 06-07-2005, 09:53 PM
sorry i meant 10-20% methanol and 80% water mix in my water injection system
