Old 09-11-2004, 07:03 AM
Default Good concept
Yes that is a good concept. I have alluded to that sort of setup on a couple of occasions here.
I will have something very similar when I get my system finished.
The multiple nozzles should give you more flexibility, and safety regarding nozzle blockage.
Old 28-11-2004, 04:05 PM
masterp2 masterp2 is offline
I am moving toward the config P-rex suggests. Would like the option of doing more vaporizing, which can't be very effective at the throttle with so little time. The hi temps assocaiated with the turbo compression will solve that. 8% humidity here, need it bad.
Old 15-12-2004, 10:57 AM
PuntoRex PuntoRex is offline
Been using the pre-compressor jet installation for a while, I did suffer from the surge problem in higher gears, especially 5th in the mid rev range on the highway. Tuning up the injection point (10psi to 12) helped some, but would suffer from the other problem - midrange det.
The weather was chilly these days, and my car det! It never act like this. I suspect that maybe the partially vaporized water from the compressor oulet condenses back to liquid within the cold IC, then the heat is back. And the liquid water in the thin IC passages is definitely not a good thing. While slightly later injection point provides insufficient in-cylinder cooling after all these chaos. It's just not right on time, especially in this fixed w/f 2D system.
So, pre-compressor WI should not be too early & too much. Especially with an upgraded compressor wheel or bigger turbo. I think this is for sure.
I managed to make a system which turns on pre-compressor jet a little later than the main (the pre-throttle) one, and one additional jet also on pre-throttle for slightly larger w/f ratio at the first injection stage. (as above)
Using the 2D's injection duty cycle voltage output as the switch reference, i.e. 3V as 60% IDC. I think this is a good point for my car which rushes to 80% at red line.
By a comparator circuit, I compare the IDC related voltage with a pre-set 3V reference, then drive a 3way/2position solenoid valve to guide the flow.
There're 3 jets:
A- main jet, running full time, pre-throttle
B- mid-load jet, pre-throttle
C- high-load jet, pre-compressor
My car is running at 20psi boost max. At the 1st stage, begins at 8psi (about 40% IDC on my car), A+B are working, for maximum in-cylinder cooling. 2nd stage, begins at 60% IDC, A+C are working, for improved compressor efficiency & less det control needs.
By doing this, it avoids the surge line on the midrange operation & stretched the choke line on the hi-load/hi-flow situation. Effectively, it extends the overall area of the compressor map, I believe.
I just got it done today (2:30 am). It's running very well in the first impression. Earlier injection point makes the car livelier on part throttle acceleration & eliminates the midrange det. 5th on highway speed is now smoother on small throttle inputs. WOT to the red stays perfect as the previous full time pre-compressor jet setting. It's running in a stretched compressor map. What a treat!
It's a good mod, worths a try.
Next, I'll try fine-tuning the stage 1-2 switch point & several different jet sizes to play with a two stage w/f ratio map....
'97 Fiat Punto GT
Old 04-01-2005, 12:56 AM
Steve VXR Steve VXR is offline
I know this is digging up a quiet topic, but I was just wondering what spec the Z20LET is running in your car please Gelf? I've just fitted a 1S system to a a Z20LET and that is running a hybrid turbo and about 24 PSI peak boost.
Old 06-01-2005, 08:32 PM
Gelf Gelf is offline
Hi Steve, standard turbo and exhaust, remapped with 19 psi peak boost
Old 12-08-2005, 09:23 PM
Originally Posted by Gelf
Originally Posted by PuntoRex
No matter it's a table or graphic, you may cut & paste onto a PowerPoint template. By that, you can "save as" a .jpg file, that would be much more convenient on this forum.
Done it, 200k jpeg.
Interesting that temps exiting the IC have cooled to below ambient by the time they reach the throttle plate. Evapouration is continuing down the 20" pipe from the IC to the throttle. Thats after the water travelled 10" to and through the turbo, and 18" to and through the IC.
Gelf, what happen to the image? I was jsut going to take another careful look.
Old 28-09-2005, 08:41 PM
ctischmick ctischmick is offline
Done it, 200k jpeg.
If we can't get the pic up, you should unsticky this thread.. its kind of useless.
Old 28-09-2005, 11:46 PM
Thread is un-sticked.
Old 02-06-2009, 12:40 PM
Tjabo Tjabo is offline
No one copied the image(s) from the beginning of this thread? It seems like there's some good information here, but it's hard to make sense of it without the pictures. . . Does that mean I'm illiterate? :lol:
