Old 22-08-2005, 02:03 AM
Those look pretty interesting.......were they hard to make? I was thinking about doing pre-turbo injection after I'm done with the WI install....if these work well please inform the fabricator I'm interested in one these.
Old 22-08-2005, 09:39 AM
They are not too difficult to make once the machine is set up. Need to make a cad cam drawing first. It is quite a long drawn out affair in both cad-cam and actual machining.
Forumadmin
Old 22-08-2005, 10:13 PM
Will_emt Will_emt is offline
Awesome!
Any risk of compressor wheel abrasion using these jet locations? What size jet will this use?
Old 22-08-2005, 11:35 PM
As the main panel is updated with FIA2 and HSV, the twin valve is now used to direct the water to perform two tasks, pre-turbo and port water injection. The water flow is progressive with fuel's DC or a third party WI map.
Old 26-08-2005, 08:18 PM
The HSV is now in place to manage water flow to the pre-turbo and port injection valves (picture above).
Old 26-08-2005, 10:53 PM
Joel
Why use the machined inserts to place the jets centrally in the turbo intakes, wouldnt it work equally well to inject at 90deg to the airflow into the compressors ?
Old 27-08-2005, 12:16 AM
You may need to read this threads to find out the reasom why - it is a long story.
http://www.aquamist.co.uk/phpBB2/vie...er=asc&start=0
May require signing in, worth the trouble, tons of information there.
Old 27-08-2005, 05:51 PM
My set up is similar , but I have both HSV's , down stream each of the solenoids , so that they dont see my ystem pressure all of the time.
Old 27-08-2005, 05:52 PM
A pair of precooler is now ready to be fitted to the skyline, will report on the results.
I am very much interested in a pair of these too , what size are they , 3 " ??
Old 05-09-2005, 08:11 AM
The size is 2.75" , but it can be rescales before machining. The dseign of the precooler bracket is not yet finalised - it wil depend on the out come of the next few days,
