Old 12-03-2014, 11:36 PM
dave80 dave80 is offline
Default Re: False flow readings from flow sensor.
Not yet. I think engine vibration was my problem, but now I'm closer to the hid headlight with the fav assembly so I will see if that will cause any problems. Worse case scenario I will spend the $15 and use the shielding.
Old 14-03-2014, 08:22 AM
Please keep me posted.
Old 12-05-2014, 10:37 PM
no false flow readings anymore, since I moved the fav assembly to a new location
Old 13-05-2014, 07:07 AM
This is good to know.
Why is the VW engine bay more prone to vibration than others?
Old 13-05-2014, 12:19 PM
stiffer engine mounts, maybe the turbo itself had something to do with the readings since it was pretty close to the fav.
Old 11-06-2014, 02:11 PM
johntotah94 johntotah94 is offline
So did you guys solve this by wrapping something around the FAV?
Old 11-06-2014, 11:40 PM
Originally Posted by Howerton Engineering View Post
We have worked on this with a few customers lately, and found the negative battery cable is also a source of noise. It seems the source of noise is different from car to car, but there always seems to be something causing it.
Of the installs I've been involved with I have never experienced this first hand so all I can do is pass on what others are reporting and coming up with.
How did you end up blocking the noise from the battery cable?
I am getting a lot of noise leaving the flow sensor gauge bouncing around with my HFS-4 in my Mini Cooper S
