Old 13-06-2005, 01:42 PM
Bikenuts Bikenuts is offline
Default Diesel, propane and water?
I have a Toyota Surf with a 3 litre turbo diesel, the engine currently runs 130bhp @12psi without an intercooler, I?ve fitted propane fumigation but find the power gains I can achieve limited by the onset of knock and high EGT (1350f + / 825C+) as there is no space for an intercooler without extensive body mods and / or miles of pipe work I was considering trying water injection. Does any body have any experience with this sort of set up? What sort of water flow should I be starting with? ( I live in the north of England ambient temp 32-64f / 0-20C)
Cheers
Matt
Old 05-08-2005, 02:22 AM
David David is offline
Matt,
I have evaluated a LPG kit by a company called Diesel on Gas they are based in Adelade.
The kit consists of a Derating module /ECU Harness etc easy to fit,gives loads of power/emission reductions,
check out there website.
cheers
David
Melbourne/Aus a yorkshire man from Leeds
