Old 03-09-2004, 05:05 AM
jt2ma71 jt2ma71 is offline
Default Motec m800 supra turbo with Aquamist 2C
MoTeC M800 Supra
533 RWHP @ 21 psi
Old 19-09-2004, 04:06 PM
Do you have a few more pictures of the install?
Old 19-09-2004, 04:30 PM
Yes, I do. The pump is right behind the front license, in front of the intercooler. The pressure switch and injector are shown on top of the Intercooler.
Old 20-09-2004, 08:59 PM
This is a real interesting place to pump the water pump, nice and low, pretty dry as well.
Great pictures. Thanks. Is your water tank in the back?
Old 22-09-2004, 01:56 PM
Thanks! The tank is just below the passenger side headlight. The bottom of it is about level with the pump, maybe a little higher. The nozzle is on the IC pipe just below the driver side headlight. Very short path for the water to travel, but I don't think that matters anyway.
--Ron
Old 25-12-2004, 10:56 PM
Richard, the plug on the bottom part of the manifold, oppossite of the pressure switch, can I take that off and put a pressure gauge/sender instead? what is its size?
Thanks.
MoTeC M800 Supra
533 RWHP @ 21 psi
Old 27-12-2004, 08:31 PM
Thanks.
You can use any spare port, they are all connected internally. The thread size is 1/8 BSP bot 1/8 npt will fit - require a little bit of PTFE.
Just a matter iof interest, does the pump get water splashed?
Old 29-12-2004, 03:33 AM
[quote="Richard L"]
Thanks.
<<<You can use any spare port, they are all connected internally. The thread size is 1/8 BSP bot 1/8 npt will fit - require a little bit of PTFE.>>>
Thanks!
<<<Just a matter iof interest, does the pump get water splashed?>>>
You mean when driving in the rain? I would imagine it would get some water splashed onto it, why? I have the connector/plug tied up and behind the bumper where water does not get to.
--Ron
