Old 28-04-2005, 01:47 AM
franz
Default 2003 Mitsubishi Evolution Aquamist
Here is another car we just finished up...
2003 Mitsubishi Evolution w/ Aquamist 2d system
Rear mounted water tank (internally baffled and foam filled) ~5.5 Gallons
Uses Bosch Headlight washer pump as primer pump for main system
-6 AN pushfit line to front of car (then to 6mm hose for filter and pump)
then I covered it with carpet to blend into the trunk space better... probably going to recover it when i find a fabric that better matches the stock trunk liner. You can see the primer pump on the right side underneath the tank.
bracket to hold the Pump, 30cc surge arrestor, system pressure switch, flow sensor and high speed valve uses the same mounting points as the intercooler sprayer tank (which is still functional). 4mm line from the HSV is hidden as it comes up to feed both pre and post turbo jets.
all of the electronics are mounted in the left front kick panel, while the tank level is diplayed by the "door ajar" indicator in the dash (1 gallon reserve capacity). The DDS2 display is integrated into the instrument cluster (still a little dusty in the picture).
WWW.ktrperformance.com
Old 28-04-2005, 01:00 PM
nothere nothere is offline
neat
is the monitor in the dash cluster hard to install.
your shop is a bit of a drive for me.
Old 28-04-2005, 03:29 PM
ftd ftd is offline
Originally Posted by nothere
neat
you have to dismantle the dds2 monitor and shave it down and clip a few things (and discard the case) so that it will fit into the evo's cluster... the cluster has to be CAREFULLY trimmed so that the LED bar fits flush with the mating surface and then the whole unit is epoxied into place... we can perform this service for you if you send you instrument cluster to us...
www.ktrperformance.com
Old 02-05-2005, 06:44 AM
EvoTio EvoTio is offline
Very nice installation. I especially liked the way you mounted the DDS2 moniter.
