Methanol & lubricant
This topic was started over on NASIOC (Methanol without lube in it....) and I wanted to bring it over here as there seem to be many here using 100% methanol.
Have any of you experienced sediment build-up over time in the methanol with fuel system lubricant in it? I was originally going to order a 55 gallon drum of methanol with this lubricant in it to split with a few other locals who are running water/meth injection, but if it's going to develop sediment and particulates in it over time I may just go without the lubricant and add it separately after it's mixed in the fuel/water cell. Anyone have any additional input on this? |
I cant see how you will be able to keep oil suspended in methanol. I would presume it will seperate. It will be differant to water which will mix 100 % with water in any amount
Scott
RX7 |
Looks like pure methanol may be the way to go. |
RX7 |
