Old 21-03-2012, 05:22 PM
Default Mazdaspeed 3
Old 18-04-2012, 09:02 PM
skeurton skeurton is offline
Default Re: Mazdaspeed 3
I have an aftermarket electronic boost control solenoid running in 3-port interrupt mode. It plugs into the stock harness, just like the stock solenoid. The same principles apply when tuning for it, but it requires much less wastegate duty cycle (at least 25% less) than the stock solenoid.
Can I still follow the wiring diagram above? Or does it need to be wired differently? Here is a link to the product and manual:
Product:
http://www.grimmspeed.com/catalog/pr...roducts_id=194
Manual:
https://www.grimmspeed.com/install_g...MazdaSpeed.pdf
Old 19-04-2012, 07:18 AM
Yes, you can continue using the above wiring diagram. We just cut the PWM signal to the BCV. It will work with any valve.
One reason for a lower duty cycle is needed on the grimmmspeed valve is probably due to slightly larger orifice in the ports.
Old 15-12-2012, 08:24 PM
yokimazoku yokimazoku is offline
im wondering what year mazdaspeed this diagram is for. I have a 2007 and im looking at the ecu connector pinout and it seems slightly different. The #1 fuel injector coil - on the sheet im looking at says its 2BA not 2BB. Is there any way to verify this?
Old 15-12-2012, 08:33 PM
Nevermind that example is correct ignore that post.
Old 13-04-2015, 11:46 AM
jdraps13 jdraps13 is offline
Where would I cut in order for this application? Or is this something you guys do prior?
Old 13-04-2015, 04:34 PM
If you place an order from our online shop, we will make the necessary modifications for you. But do make a comment at check out to be sure.
Old 13-04-2015, 05:00 PM
I have the kit already just wondering where the cut point is
Old 13-04-2015, 05:11 PM
If you have the kit already, go to page 21 of the user manual. If you have lost the used manual, you can download it from here. Version 3.
Old 13-04-2015, 05:20 PM
So on number 6 cut the connection to the negative?
