Old 08-06-2013, 09:14 PM
ysfg35 ysfg35 is offline
Default Windshield - which one ?
hello there ,
guys am searching for the best Windshield i can find that can
be ok with HFS3 ? contain more meth than water ??? which one should i go for ??
i found this in my area but not sure about it ..
http://vailace.com/images/Coupons/homephoto1.jpg
did anybody try it ??
is there is something else ??
Old 10-06-2013, 07:45 PM
Dust Dust is offline
Default Re: Windshield - which one ?
Where do you live? That would be the best first off. Do you have an Autozone near you? If so, http://www.autozone.com/autozone/acc...er=690800_0_0_
Old 04-02-2014, 09:27 PM
c0op3r c0op3r is offline
I can not say that its good or bad, but I can only tell you a little trick, one that you might not need as it is colder where you are, but here in FL its impossible to to find anything below 0?F Mixtures.
I did find Peak Rain Off -25
It is <30% Meth according to the MSDS Sheet
The trick is that if your local store does not stock it you can pre-paid for one to be delivered to your local store and Pep-Boys Sends a case for Stock (6) so you do not have to pay shipping, and you have a ready supply available.
To the I mix 1/2 Gallon Peak -25 with 1/2 Gallon VP M1 99.9% Meth Resulting in ~70% Mix.
Old 04-02-2014, 10:10 PM
Check your walmart for supertech de-icer or the supertech winter survival kit
http://www.srtforums.com/forums/f189.../#post10326649
