Old 01-05-2020, 07:03 PM
Krisgt30 Krisgt30 is offline
Default F13 M6 hfs 3 post install questions
I haven’t adjusted any of the settings out of the box for the hfs3 unit. Chose to hook it up via map sensor (boost via just blue and red cables) instead of injector pulse (green). I Turned on the vehicle no leaks. Gauge shows S and led lit green in the back. However under wot I am not seeing the blue bars on the gauge light up. Any recommendations for troublshooting?
Old 02-05-2020, 04:30 AM
Default Re: F13 M6 hfs 3 post install questions
Just an update, I did not wire the injectors to the system as I am running this off boost (map) and have that wired. Do I still need to wire the direct injection system to have this system running?
Old 02-05-2020, 08:28 AM
If you run boost only, you need to solder link MPS on the underside of the circuit board and cut IDC.
Also move jumper link from iDC to MPS
Old 02-05-2020, 05:16 PM
Thank you for the response will get on that ASAP!
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
