Old 15-08-2005, 08:57 PM
mrx79 mrx79 is offline
Default How to measure the right amount for a special mixture?
Hallo,
i have a quick question about mixing my Water / Methanol / Nitromethane mixture.
for example, if i want to make a 60/20/20 W/M/N mixture... how sould i measure the different fluids?
by Weight? by Volume?
i ask because when i remember my chemical class correct then Nitro has another specific weight then water and methanol right?
so how can i be sure that i get exactly my wanted mixture?
does temperature plays a role?
Hope to get some help
Malte.
Old 15-08-2005, 10:06 PM
By volme is mush easier. only water weighs 25% more then others or other weighs 20% less than water per unit volume.
The reason for this is most automotive fuel injectors are rated by volume. Water weighs more per unit volume at 4 degree C but if you measure everything at 25% deg C, The assumption above is pretty accurate.
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
