Re: HFS-4 Q&A, application for your engine...
Thanks, dave |
The output is propportional to flow but you have put your own scaling to it.
what is the best jet for tiburon supercharged 2.7L V6 boost peak at 20psi with 50/50 water-methenol?
how many run with twin tank in1/4 mile drag? how many liter when run normally with 45 liter of gas? |
Can you describe the mechanical location of the supercharger (possibly with a picture). I donlt know the car very well.
Twin tank a is two gallons or ~8 litres. If you are injecting 800cc/min at 12 second 1/4 mile passes, you will need a maximum of 160cc per run. YOu should get about 50 runs. But after 40 runs, replenish the tank due to possible sloshing if you don't have baffles in the tank. Not sure about your last question. |
( http://www.ngmhouseofpower.com/product_p/assassinsc.htm )
is the same kit with intake cooler (icebox) |
That looks very menacing. Thank you.
If you have 45 litre of gas, you can get away of 1 to 2 gal tank, per gas fill. |
but do you have an idea of the size of the jet that I will have need of? (what is the best jet for tiburon supercharged 2.7L V6 boost peak at 20psi with 50/50 water-methenol?) |
What is the size of your fuel injector?
600cc but it has not work 100%
I do not know what percentage has to work There are not yet installed |
There are the ratio works well opn most applications. It does not matter with you use up th eentire capacity of the fuel injectior. On our syustem, you can scale up the ratio with the "gain" trimmer.
100% water ....................10-15% to fuel flow M50/W50 ...................... 15-20% to fuel flow 100% methanol...................... 20-25% to fuel flow |
