I just visited radioshack http://www.radioshack.com/category.a...relay(keyword)
part number: 275-006 @3.99USD SPDT 2A 275-248 @3.99USD SPDT 10A 275-249 @4.99USD DPDT 5A They will all do what you want - they are called SPDT or DPDT S=single D=double T=throw P=pole. |
Thanks, Richard. I went to their website but didn't know which one would work for me. Thanks again!
A single pole single throw normally closed or single pole double throw using the normally closed pole will cross over the binary ground logic from XEDE or UTEC to the trigger needed for the 2d. Just about any normal automotive 5 pin relay will be suitable - most automotive places will have a Bosch or other make around. Look in fog light, auxilarry horn sections since they are usually required for those applications as most switches will not support the draw of those items.
Thanks to you to charged performance.
For anyone that is interested in switching the ground logic of the Aquamist triggers.
Normally there will be two pins on the relay for the solenoid this will have a rectangle with a line going to each pin - one pin will go to a ignition switched and fused 12v line, the other will go to your UTEC trigger. The solenoid is not normally polarity sensitive. When the UTEC grounds the solenoid will activate. Then on a SPDT 5 pin automotive relay there will be a common pin a line will be connected to it - this goes to ground. (PS I forgot most 4 pin automotive relays are only normally open - you probably won't find a normally closed one without a special order) One of the pins will have a line on the schematic going to it but not touching - that is the normally closed position. Usually this is the center pin. That pin goes to the grey wire. While grounded the system will be ready but not operating. When the UTEC grounds the solenoid this normally closed circuit (grounding the grey wire) will open (ungrounding the grey wire) triggering the system to do its stuff. The other pin that has no line on the schematic is the normally open pin nothing goes there, unless you want an LED to show when the system has been triggered. In that case run a wire from the relay to the (-) side of a 12v LED (or LED with proper resistor). Then whenever the system is triggered the LED will light. |
Thank you Charged Performance, that is the rest of the info I needed. I can install or fabricate just about anything, but the electrical stuff is not my cup of tea. :oops:
