-   Aquamist HFS-6 forum (http://www.aquamist.co.uk/forum2/vbulletin/forumdisplay.php?f=32)
-   -   fail safe for centrifugal supercharger (http://www.aquamist.co.uk/forum2/vbulletin/showthread.php?t=1691)
flyinryanp 26-03-2010 08:17 PM
Re: fail safe for centrifugal supercharger
i was going to tap the throttle body itself sorry for the confusion. i just wanted to make sure there was no siphoning problem on these systems.
Richard L 26-03-2010 10:14 PM
Next to the throttle may not be the best place as droplets can quiclkly be taken out of suspension when they make contact on a surface. This will decrease the rate of vaporation several folds.
Put the jet at the exit of the SS is not a bad idea.
flyinryanp 27-03-2010 02:00 AM
m y boss got ahead of me and went ahead and tapped the throttle body and put them in front of the throttle plate at an angle if that doesnt hepl explain it ill take a picture of the actual throttle body
http://img521.imageshack.us/img521/7...ottlebodyp.jpg
thanks for your time and help so far bye the way
Richard L 27-03-2010 09:36 AM
It is always possible to plug it up with the supplied jet adaptor plug. Ensure the the full spray pattern is not affected by the angled installation.
http://www.aquamist.co.uk/forum/spray-angle.gif
Please let us know how it performs as it is.
stevieturbo 28-03-2010 12:05 PM
Why not speak to A&A ?
Putting the nozzle AFTER the air charge temperature sensor is not a smart idea. Its best for the ecu to see the temp change.
As for lowering boost, that is very easy to achieve. Just block or vent the signal line to the air bypass valve or BOV ( using a simple solenoid ). If this doesnt have boost pressure applied to it, it will simply blow open causing a very sudden boost drop.
IMO putting the nozzle where you have, is far from ideal.
flyinryanp 29-03-2010 06:59 AM
thankyou for your guys input
