-   -   Pump problem (http://www.aquamist.co.uk/forum2/vbulletin/showthread.php?t=2048)
Richard L 23-08-2011 11:59 AM
Re: Pump problem
in this case, it has to be the controller.
Can youn check the soldering is good on the RJ11 socket.
sebdut 23-08-2011 12:36 PM
Re: Pump problem
Yes all seems to be good
sebdut 23-08-2011 01:01 PM
Re: Pump problem
Is it normally that I have 12v on the green wire when I am on pr? cranck position??? The green wire is not for the inj-? I have a french RS4
Richard L 23-08-2011 06:01 PM
Re: Pump problem
The green wire is on the other side of the fuel injector coil. At pre-crank position, you should see a full 12V when the fuel injectors is not being pulsed.
Some vehicles switch off the +12v supply to the fuel injected if you don't crank the enigne for a preset period. This is for safety reasons.
It appears this is a problem on ther relay driver. Please return the circut board back to me for checking.
sebdut 23-08-2011 07:43 PM
Re: Pump problem
Ok let me know your adress and I send you that tomorrow
Richard L 23-08-2011 08:14 PM
Re: Pump problem
ERL Ltd
Iroko House Returns dept.
Bolney Avenue Peacehaven
East Sussex BN10 8HF
England
sebdut 24-08-2011 12:59 PM
Re: Pump problem
The controller is send :-)
Richard L 24-08-2011 02:44 PM
Re: Pump problem
Great, I will be looking out for it.
Ricgard
Richard L 28-08-2011 02:41 PM
Re: Pump problem
I have received the unit on Thursday.
I just did some simple tests and cannot replicate the problem of the relay, the system switches on the relay positively without any problem.
Since I have the unti back, I can flash in a more suitable flow table to suit your applciation. Can you tell me how many and what jet size you are using. I will send you a new relay just in case.
Richard L 28-08-2011 03:48 PM
Re: Pump problem
Can you make a visual check for me on the blue harness. The order of colour in the RJ11 connector should be Red, yellow, blue, black. Counting from the gauge side.
I think this can be the problem.
