Re: 997TT issues?
All the wires are correct, do you have the order for the gauge, the shop had to order a longer cable, I just want to make sure it's correct. |
Re: 997TT issues?
Checked with factory gauge wire and still the bar graph is not lighting up. Also the water level light is green when the kit is on. I have the pin DFS jumped, because when its not jumped both lights turn yellow under boost.
Re: 997TT issues?
Re: 997TT issues?
Re: 997TT issues?
Re: 997TT issues?
Can you tell me if the gauge displays more bars when SC is turned clockwise.
Question, how many jets are you running? |
Re: 997TT issues?
Jets? I have 2 Nozzles into my intake. No restrictor in the fav. |
Re: 997TT issues?
Please test the SC trimmer as follows:
ignition on: Put the "PRK" jumper link to "BAR". Twiddle the SC, you should see the bargraph go up and down. Let me know the result. I have one more question, can you tell me the serial number of the controller (botton left hand corner) |
Re: 997TT issues?
SN: 10430
I set the jumper on the BAR and it did move the bar graph when I adjusted SC on the gauge. |
Re: 997TT issues?
So far, all test results are positive.
The next test will be getting the two jets out of the charge pipe and watch the spray pattern and bars on the gauge, using the "SYS" test jumper. Don't do it more than a few seconds at a time. PLease post results. |
