Re: problems with FAV solenoid - no work, but getting very hot!
But I will check again, because after recent service which included whole rebuild of cylinder block anything can be changed... |
You need to change the transistor first. It should not cost more than $1.00 a piece. |
I did not connect it to the solenoid before my tests - and it immediately showed 13.0V on the harness... seems like transistor was blown immediately after I start the system. p.s. and you won't believe, but they sell such transistors here in Russia for $3.00 (while purchase from manufacturer at $0.75 - I know the real price)! |
Next step...
Can you check the voltage of the controller ground (bottom left of the test points), against chassis ground. |
sure, will do it later today once I'm back home.
should I measure impedance between ground and accumulator (-) chassis as well? |
Just to measure the controller ground against chassis ground. This is to check the system wiring.
Chassis ground is any exposed metal on the car body. What is the accumulator? |
the voltage on 'ground' reference point is 0.00V when off and 0.01V when switched on.
the impedance is 0.0 Ohm when off. sorry for using wrong term: by (-) accumulator I mentioned (-) on car's battery which is linked to chassis on my car. what are next steps? I see lots of diagnostic points on the mainboard - should I check them? also I have checked again the information from fuel injectors (I have direct injection car) - it is correct and there are no problems here. the same about information from flow sensor and trunk harness... |
This is good, no wiring problem there.
Please check the voltage of the following test points (against controller ground): (with the ignition on, engine not running) 1. test point 5 injector(+) 2. test point 8 injector(-) 3. test point 23 injector(+12) 4. test point 1 FAV drive (check resistance. not voltage) 5. test point 16 (IDC%) 6. test point 15 internal 5V reference 1 7. test point 11 internal reference 2 8. test point 30 internal reference 3 That is all for the time being. I would also like to have a good picture (well focused) of the controller circuit board (top side and bottom side). Like to see the settings and configurations. |
Is it okay if I will test all reference points without FAV solenoid connected?
Since it is always under voltage it is getting hot which is not good, I assume - ok? Also, what to you mean by 'test point 15 internal 5V reference 1' - what is reference 1? Should I check all voltages and impedance (resistance) vs. 'ground' control point on the mainboard? |
