-   Aquamist HFS-4 forum (http://www.aquamist.co.uk/forum2/vbulletin/forumdisplay.php?f=48)
-   -   failsafe setting (http://www.aquamist.co.uk/forum2/vbulletin/showthread.php?t=2560)
Richard L 02-03-2014 04:53 PM
Re: failsafe setting
Originally Posted by lailarry (Post 19978)
I need to check my car EGT is 0-5v but my O2 sensor is narrow band not wide band. Still the same question.. how about my gain, if I will decrese it , I need to CCW ...
Decrease it = CCW.
Richard L 02-03-2014 04:55 PM
Originally Posted by lailarry (Post 19979)
I found pin 16. But how to get the voltage during driving ?
1. Do you have a extra 0-5v channel for logging?
2. How did you check the DC% before?
lailarry 02-03-2014 05:08 PM
I used VAG-COM to log and video camera to record DC %.
Richard L 02-03-2014 05:20 PM
Please post so results here, it is interesting to see.
lailarry 02-03-2014 05:27 PM
yes. I will post here. But Why I need another one 0-5V channel ? Because I had one failsafe channel cutting boost from my N75.
Richard L 02-03-2014 06:01 PM
The extra failsafe channel is input. When triggered, It performs the same "boost cut" action to the N75.
Some people are more concern on what the engine is doing as well as monitoring aquamist's water/methanol flow. So we introduce this additional option on the HFS4. You don't need to use it if you don't want to.
lailarry 02-03-2014 06:12 PM
1 Attachment(s)
May I know on Aquamist HFS4 pre-amp gain ( solder link x1.0 x1.5 x2.5 ) and Aquamist HFS6 "IDC trim" trimmer is the same function ?
Richard L 02-03-2014 06:30 PM
I see, the HFS6 does have an IDC trimmer but not the HFS-4. It uses pre-amplification instead.
We feel having the fixed PA gain is easier to set up. We have found user end up wearing out the IDC trimmer before an ideal PA gain is determined.
On the HFS4, you can use the PI-R as the H6's IDC trimmer, provided you do not use the MPS input. If you want to reduce flow, just turn the PI-R trimmer CCW.
You seemed to know the aquamist system very well.
lailarry 02-03-2014 06:42 PM
I just contact Aquamist for 4 weeks. But read a lot of discussion from web. Try to do it by myself. Thanks
Richard L 02-03-2014 07:01 PM
You know where to find me if you need support.
