-   -   Direct Port EVO IX rs HFS3 (http://www.aquamist.co.uk/forum2/vbulletin/showthread.php?t=2860)
Richard L 31-03-2016 08:11 AM
Re: Direct Port EVO IX rs HFS3
The 5th jet (post IC) should be the air cooling work. The port jets will do the the combustion chamber cooling.
Iguanapeluda 31-03-2016 08:57 PM
Richad, I have a question.
If I put the jet in the place that you are tell me...is possible that the water spray crash with the intake and condensed water?...
http://i67.tinypic.com/5p5251.png
It will be better install the jets in the final of the runners opposite injectors with an angle like the inyectors?
http://i67.tinypic.com/demx47.jpg
Thank you!!!
parmas 31-03-2016 11:08 PM
Condensed water will eventually continue cooling the charge even when no water is injected
Richard L 31-03-2016 11:49 PM
The mass of air flowing across the spray will be around 2kgs/min. If you are injecting 100g/min, what are the chances of the spray hitting the opposite wall?
Answer, very little.
The aquamist jet has a spray angle of ~80 degrees. You cannot angle the jet too much or risk spoiling the spray pattern. If this happens, you will loose 25% of the atomisation. If you want a good atomisation, point the jet against the air flow.
http://www.aquamist.co.uk/forum/spray-angle.gif
Flr Power 01-04-2016 12:54 AM
It doesn't matter. If you think about it, some water will make it's way to the intake valves and sit there waiting for the next engine cycle.
Iguanapeluda 03-04-2016 05:06 PM
Well....finally...
What do you prefer...
In this place? With this installation...
http://i66.tinypic.com/2ebtu0m.png
http://i66.tinypic.com/jqtkq8.jpg
Or in the initial place? (Number 1 place)
http://i63.tinypic.com/do3z28.jpg
Richard L 03-04-2016 05:39 PM
90-degree is the angle I recommend and the easiest. But you can try other angles if you prepare to make the jet adaptor to fit properly.
Iguanapeluda 03-04-2016 05:49 PM
Ok ok, I will put 90š in the "1" place.
Thank you Richard, I will inform for the updates with the installation.
Iguanapeluda 05-04-2016 08:44 PM
Well...jetīs installed in the only place that I can put...
http://i67.tinypic.com/30cxhs7.jpg
http://i64.tinypic.com/2u5x16d.jpg
http://i64.tinypic.com/bhkoqp.jpg
And the fifht jet:
http://i63.tinypic.com/2mo5thj.jpg
Flr Power 05-04-2016 08:52 PM
Don't use these clamps with boost.
