Re: RICESP Water Injected RX7
I am doing some more design/manufacturing of some special bits so not much time to enjoy it :( Here is a very quick mock up of the concept, now to get busy designing and making!@!!!@!!@!@!!! http://i.imgur.com/JV2UuFc.jpg http://i.imgur.com/mOwpn31.jpg http://i.imgur.com/pO49bLV.jpg http://i.imgur.com/RIFmjdk.jpg Here is what I have done so far............... http://i.imgur.com/80LcqUe.jpg |
more progress!
http://i.imgur.com/6J2yuEH.jpg bottom bracket to go, then need to procure the switches I want to run and add those, then can machine the poofters up! |
Finished main part of design process, will finish off other little details like button placement and boost pot multi position switch and Andy's requested NOS button!
Looks good. http://i.imgur.com/44BwE3f.jpg http://i.imgur.com/AEUPdvb.jpg |
Couple more angles, 3am this morning nearly finished it lol!@
http://i.imgur.com/Iqk3n83.jpg http://i.imgur.com/kYqhsmp.jpg |
Well that's a good ideas receiver grooves for the side seals
What's the main issue when doing that? Heat expansion of the metal moving the seals?
Have you reached the max amount of boost to run on your engine or is there still more in it? Could you run more without having to modify your WMI?
What sort of torque are you making with the HP you are producing? |
