Re: Pre Turbo Injection - How Much and When to Inject
parmas, Did you ever check your timing for drift at high rpm with a timing light?
Also I just realized you said you inject at 60% water/meth fuel ratio. I have only tuned to about 30% ratio so you are in a different league. I remember when you used to spray very little and now you spray a lot. Good work by the way! |
At such high water to fuel ratios and a lean mix, the ignition timing numbers look more feasible. I won't use that much mix as otherwise fluid usage on track would become too high. I only run a 1 gallon tank.
Fast Yaris. I liked it. Are you using a PWM valve to adjust flow over rpm/boost? I control flow via a aquamist HSV and a separate map in the ECU. |
I am going to bump this thread because I am running pre-turbo but not with an Aquamist system.
I choose AEM because 99% of the time WMI will be used is WOT and I'm not interesting in pulling base fuel and replace it with methanol via the water injection system. I also choose this configuration because I want to get more out of the stock turbocharger. Starting with the smallest included nozzle (250cc/min), I wasn't sure if it was working like it should. Turns out it did work but eventually some air got caught in the system and it stopped pumping water. I had to undo lines on both sides of the pump to get it primed again and the water flowing. Logged a short 4th gear pull and sent it to my tuner. Apparently there was enough of a change that he modified my tune. I had changed the nozzle to the middle one included in the AEM system (500 cc/min). Right now I have inlet temps 6 degrees over ambient though that log was taken well into the evening as ambient started to drop from a mid day high of around 97 (F). This is only the beginning of what's the come. |
