-   Aquamist HFS-4 forum (http://www.aquamist.co.uk/forum2/vbulletin/forumdisplay.php?f=48)
-   -   False flow readings from flow sensor. (http://www.aquamist.co.uk/forum2/vbulletin/showthread.php?t=2440)
hotshot25120 18-09-2013 05:45 PM
Re: False flow readings from flow sensor.
I have to to move the assembly and now its wrost here a picture of the new setup :
http://i62.photobucket.com/albums/h9...ps5e9debc9.jpg
I have try to unclip the sensor and no false reading when the sensor is unclip.
Richard L 18-09-2013 05:57 PM
That is great, we eliminated one thing for now.
It that case, rotate the sensor to three o'clock and see if the ghost reading goes away.
hotshot25120 18-09-2013 06:21 PM
I have done a quick test at idle and
12 oclock = false reading
3 oclock = no false reading so far
9 oclock = false reading
Richard L 18-09-2013 07:04 PM
I believe the turbine is fluttering between the poles at certain angle and create false pulses.
How far is the jet from the FAV?
hotshot25120 18-09-2013 11:58 PM
1 foot from the first jet (after Throttle body (check valve))
3 foot from the lower jet (after intercooler)
Richard L 19-09-2013 12:26 AM
Is this problem happened recently?
dave80 19-09-2013 12:30 AM
your fav still is right on the engine mount. It will cause false readings, see pic below for what has worked for me.
http://i246.photobucket.com/albums/g...0/NCM_0017.jpg
hotshot25120 24-09-2013 09:04 PM
after some day of testing with the sensor in the 3 oclock position I still have false reading sometime but its way better than before.
I will try to move the assembly close to the windshield washer tank but before I need to reorder some small tubing because It will be too short.
Richard L 25-09-2013 07:32 PM
The rocking of the turbine wheel in the sensor is the most likely cause of the false readings.
The turbine wheel is magnetised. Polarity flip when rotates. Producing electrical pulses from the Hall Sensor Chip inside the "C-clip."
Depending on the orientation of the turbine wheel relative to the Hall sensor, a slight movement will produce a pulse. If the position is very closed to the flipping of the magnetic poles. Slight vibration will produce false readings.
By rotating the c-clip diametrically, you can avoid false readings. Or place the FAV away from vibration.
hotshot25120 21-12-2013 02:11 AM
bad news after reordering some tubing and relocate the flow sensor exactly where Dave80 sensor is and I still have a lot of false reading.
