-   -   Jet size Porsche! (http://www.aquamist.co.uk/forum2/vbulletin/showthread.php?t=1026)
Maikauto1974 10-04-2006 12:18 PM
Jet size Porsche!
Hello!
I am from Austria and I have the 1s system in a porsche 993 twinturbo ists for hill climb racing.
Today I have one 0,7mm jet between the intercooler and the throttle body.
Now my question. What ist the best size for this engine?? Now i have 600HP.
Ist the 0,7mm jet enough or should I change it to two 0,6mm jets.
Thanks.
JohnA 11-04-2006 09:34 AM
I would prefer the two 0.6mm jets, because they would both flow the pump to the maximum (350cc/min or thereabouts, not bad for your power levels)
Atomisation might be better too --- depending on where they are pointing obviously.
Ideally you don't want them pointing at a wall, or having tight bends afterwards, because atomisation will suffer and -more important- might vary from cylinder to cylinder.
I'd be interested in what others think. :smile:
markbudgen 11-04-2006 06:41 PM
Hello,
I've been running a 2 stage system on my supercharged 993 for about 3 years now, no intercooler. I run a 0.6 as the 1st stage to avoid too much flow at low rpms and add a 0.7 from about 4500 rpm up. 50:50 methanol:water mix. My water:fuel ratio varies as a result from about 8-15%. I also use a pre-pump priming pump to boost the flow potential of the race pump to about 450cc / min tested with good atomisation. The car just loves it. I have tuned the car AFR lamda as a result to between 0.84 and 0.87. You will probably need a little more than me given mines only putting out about 380hp.
BR, Mark.
