-   -   vacuum injection (http://www.aquamist.co.uk/forum2/vbulletin/showthread.php?t=1047)
george wallis 25-04-2006 08:59 PM
vacuum injection
will this work on a deisel, I use it on all of my gas vehicles 53 harley 45 servicar, 71 lincoln markIII, 53 power wagon, 95 dodge ram 4x4, 01 pt cruiser, 92 dynasty, and others that I have done for friends using the Ron Novak method of vacuum injection. Can this be done in the same manner on a deisel? if so where can I hook it up towards the manifold? Has worked very well on everything that I've put it on, my 95 ram is up towards 4 mpg, 10 to14 mpg really makes me smile, and seems to improve with every fillup. I use a similar mix to what I've seen posted here and can only imagine that a deisel makes vacuum the same as a gas motor, if I'm wrong tell me. thanks for sharing this site and have a great day. George
Amuse 25-01-2007 04:01 AM
diesels try not to make vaccume no throttleplates to slow the incoming air down and all that. add that most modern diesels ar turboed and you hav a bit a a bind trying to fins a spot with enough vacume for that sytem, also preignition is not a problem for diesels so they gain less.
HarryMann 08-05-2007 10:33 AM
I think that's wrong, Turbo-Diesels just love water injection...
hotrod 10-05-2007 12:05 AM
yes Diesels like WI especially with methanol added, but using manifold vacuum will not work on a diesel, you will need to use some sort of pressurised spray system.
Dust 30-05-2007 04:29 AM
where can I learn more about vacuum injection?
HarryMann 30-05-2007 10:47 AM
A carburrettor forum? :wink:
