-   -   Rich AFR's when running 50% Methanol Water Injection...... (http://www.aquamist.co.uk/forum2/vbulletin/showthread.php?t=1448)
Daxcossie 21-08-2008 02:33 PM
I decided on running with a 50% methanol mix and my AFR's have gone way too low.
Set-up is on Race Aquamist Pump, single .6 jet on inlet size, activates @ 40 degrees / 14psi.
I will have to go back to using distilled water only as the AFR is too rich as soon as the methanol get injected into the system.
http://i5.photobucket.com/albums/y17.../DSC030751.jpg
keithmac 21-08-2008 10:11 PM
Methanol is a fuel, you need to either re-tune the car leaner on the fuel injectors when the WI is active or go back to straight water.
If you tune for methanol, you need good safeguards to prevent a lean condtion due to any fault in the WI system.
