-   -   Acquamist on a Golf IV 1.6 105HP (gasoline) (http://www.aquamist.co.uk/forum2/vbulletin/showthread.php?t=1641)
breakingsynapse 23-02-2010 03:11 PM
Hi everybody... I'd like to install the Acquamist system on my ordinary car, in order to save gasoline during my many travels. Could anyone give me some advice?
-Is the system effective and affordable for my purpose? The exhaust system will be damaged?
-What size of injector should I use, and the quantity of water per minute? ...I'm not interested injecting methanol.
-What kind of pump should I install, and so, how much current is supplied to it?
Thank you for your help... :D
Richard L 03-03-2010 08:03 PM
I would not expect a great deal of economy gain by adding a water injection system especially for a non-turbo engine. Th eonly way you can get better mileage from the same engine is by increasing the static compression ratio and use water injection to suppress knock.
But, if you are suffering from bad fuel of high ambients, there will be some small benefit. Water inejction can then be used to recover the powwe loss.
breakingsynapse 11-03-2010 03:38 PM
Re: Acquamist on a Golf IV 1.6 105HP (gasoline)
Thank you for your answer ... I'll let you know the results when I install the system ;)
