-   Gallery - NEW (http://www.aquamist.co.uk/forum2/vbulletin/forumdisplay.php?f=30)
-   -   HFS-3 in EVO VI (http://www.aquamist.co.uk/forum2/vbulletin/showthread.php?t=1759)
taiman 06-05-2010 12:28 AM
HFS-3 in EVO VI
Just added water and all this popped out
http://i913.photobucket.com/albums/a...1032010027.jpg
after understanding what everything is and does i came across this problem, the tank outlet was already in place and the pump inlet didnt agree with it.
http://i913.photobucket.com/albums/a...6032010033.jpg
http://i913.photobucket.com/albums/a...9032010099.jpg
so i bought 6mm push in fittings to do this.
http://i913.photobucket.com/albums/a...0042010252.jpg
taiman 06-05-2010 12:31 AM
Re: HFS-3 in EVO VI
drilling of injection points, just before the throttle body
loctite ing in place
http://i913.photobucket.com/albums/a...8042010236.jpg
http://i913.photobucket.com/albums/a...8042010238.jpg
lower coldside piping picture
http://i913.photobucket.com/albums/a...7052010267.jpg
taiman 06-05-2010 12:39 AM
Re: HFS-3 in EVO VI
from the boot to the outside
http://i913.photobucket.com/albums/a...0042010249.jpg
from the back to the front
http://i913.photobucket.com/albums/a...0042010251.jpg
FAV mounting, underneath the engine bay chassis rail
http://i913.photobucket.com/albums/a...0042010247.jpg
covering everything with split tube cable protectors
http://i913.photobucket.com/albums/a...0042010245.jpg
http://i913.photobucket.com/albums/a...0042010246.jpg
to be continued...
taiman 09-05-2010 06:21 AM
Re: HFS-3 in EVO VI
used velcro to make it stay
http://i913.photobucket.com/albums/a...8052010269.jpg
now just to mount the tank and tune
Richard L 09-05-2010 09:28 AM
Re: HFS-3 in EVO VI
This install is well thought out. I didn't want to post earlier until you have finished. Congrets.
One the tank install, is there room for the level sensor?
Please test run the system before tuning.
taiman 11-05-2010 11:59 PM
Re: HFS-3 in EVO VI
thanks Richard,
if you have a closer look at the tank pictures, the level sensor is in place at the back end of the pump.
came pre-drilled and installed by Howerton Eng.
just waiting on anti-slosh foam now for further piece of mind.
