-   Avoiding Disaster (http://www.aquamist.co.uk/forum2/vbulletin/forumdisplay.php?f=20)
-   -   Led 5th injector notification (http://www.aquamist.co.uk/forum2/vbulletin/showthread.php?t=1957)
a1dale 25-03-2011 07:15 PM
i have an escort rs turbo i have fitted it with a 5th injector and a mf2 unit with red plug
its all working perfectly but what i am trying to do is attach an led to the injector wire close to the injector and the led is going to be on my dashboard so that i know that the injector is working so i know im not going to damage my engine by running it too lean.
i need to know if this is possible i had a quick try but when i connected the led to the injector the injector stopped working. This was done using an led with a resistor to bring it to 5v which now i am not sure is correct.
I have found out that there is a +12v that goes to the injector so the feed must be - but it maybe +7v or something i am thinking?
Please help
Richard L 26-03-2011 10:41 AM
Re: Led 5th injector notification
All you need to do is run a 12V led (with internal resistor) or any led with an external resistor (~1K ohm) across the twop wire that goes to the 5th injector (red/brown).
