info needed
hey guys i currently have a nissan pulsar gtir motor in my car which is managed by autronic. In the not to distant future i will be upgrading turbo, (maybe to gtx3071r) with 1000cc injectors and possibly hfs-3 for water injection. I have already upgraded my fuel pump and have more than adequate cooling for my future turbo as well as using 4 blaster coils with a cdi ignition box.
My question to you guys is what exactly would i be needing in my kit to make my install go smoothly. what size jets would also be needing? i appreciate all the help dain |
Re: info needed
Will you be using 0, 50%,100% methanol?
The HFS-3 is suitable for your set up for sure. The HFS-3's IDC% rescaling is necessary for your applciation because if the large injectors. |
Re: info needed
I am using only water
