-   -   HFS-5 Pump Question? (http://www.aquamist.co.uk/forum2/vbulletin/showthread.php?t=2027)
infinkc 14-07-2011 10:58 PM
Not really sure were to post this, so im putting it here, would be nice to see a child forum open for the older systems.
What affects would putting a 135psi pump or higher 150psi on an hfs-5 have? the unit originally came with a 125psi.
thanks!
Howerton Engineering 15-07-2011 06:59 AM
Re: HFS-5 Pump Question?
Realistically the HSV is not meant for more than 125psi pressure. If needing to use one of the newer Aquatec pumps the pressure can be reduced ont he nose of the pump with the bypass adjusting screw.
