BMW Mini-R56 USDM wiring
Re: BMW Mini-R56 USDM wiring
Thank you! Install starts tomorrow as it will be +12C so the weather is on my side!
Please send some install pictures. Check the underboard settings are matching the above drawing just in case.
Is this wiring diagram applicable to the 2011+ N18 engine?
I looked into this briefly. The N18 DME is still made by Siemens I cannot verify the the pin out compatibility.
N14 Engine - N14B16AC (171hp / 177 ft-lbs) * infinitely variable single VANOS (intake only) * Siemens DME MED17.2 engine management N18 Engine - N18B16M0 (181hp / 191 ft-lbs) * infinitely variable double VANOS * map-controlled oil pump * variable valve timing (Valvetronic) with 3-phase servomotor and integrated eccentric shaft sensor * composite camshaft construction * new piston design * Siemens DME MEVD17.2.2 |
Hi Richard,
Excuse me for being the first post I've ever made on this forum, but I've had my HFS-4 installed for about 3 weeks now and I wanted to know if I have this set up correctly... I have a '10 MINI Cooper S and currently I'm running without any type of restrictor and a 0.7mm jet. The injectors in in a R56-S is rated at 380cc. I'm also running a 50w/50m. Have I set up my system right? Here's an image of my board... http://img.photobucket.com/albums/v3...c/IMG_1030.jpg |
Welcome to the forum.
I think you should put in the 0.7mm restrictor. The setting looks good. if you have any slight mis-fire at high RPM, please up your meth ratio. Can you tell me where are you putting the jet? |
Thanks Richard. I have the jet located just after the MAP sensor. I wanted to place it where Jeff Howerton had placed it in his guide on the hard plastic, but knew it was going to take a bit more work to get the hole set up and it was easier access to place the jet.
I was running a 50m/50w, but now trying a 70m/30w mix. What would cause the mis-fire at higher RPMs? |
Did you have a misfire?
I haven't with the current setup.
