failsafe
hey richard i developed a problem in the past few days ... when im in full boost both lights (yellow) are on causing a boost cut the system works fine under normal driving it only does this if i really get on it. im running the new hfs3 with dual 7s jets ..... thanks
Re: failsafe
Does the guage show flow?
Re: failsafe
yes it does, about 7 bars max and B light steady.
Re: failsafe
Good.
What is the SC. WL and WH set to at the moment? Describe as the face of a clock. |
Re: failsafe
sc at 2 clock, wL 1 clock, wh 10 clock
Re: failsafe
I think the failsafe setting a bit too aggressive. Please try the folllowing:
SC at 1 o'clcock WL at 11 o'clock WH at 1 o'clcock |
Re: failsafe
Thank you sir.I'll try this and report back.
Re: failsafe
so i set the gauge at the above settings, the only problem im having now is the water level light comes on and stay solid on slight acceleration. before both lights would stay solid on high boost.
Re: failsafe
There are two things happeniung at th esame time. Failsafe and water level sensor.
Unplug the water level sensor (near the tank) and tell me what the result is. |
Re: failsafe
ok mr Richard here whats happening now . 1. water level sensor unplug.2. failsafe disable from n75 valve.3. gauge still set as you stated above. just came back from test drive, gradually getting into boost no pproblem,then when i step on it full boost both lights comes on solid.flow bars at 7-8 and B light steady at full boost. thank you really appriciate all the help...
