-   -   jetting size and restrictor (http://www.aquamist.co.uk/forum2/vbulletin/showthread.php?t=2395)
dmotors 28-12-2012 04:50 PM
i have a 4 port kit for my evo 9 i have 1000cc inyector size im planing to use up to 30 psi of boost and to get 20% and a mix 50/50 .
i calculated 0.4mm jets, what restrictor i have to use if the calculation is ok
Richard L 02-01-2013 09:32 PM
Re: jetting size and restrictor
Please allow a bit more head room for the calculation. Small jet suffers more losses.
I think a 0.7mm restrictor is about right.
dmotors 03-01-2013 03:32 AM
Thanks richard , my calculation is ok for the aquamist jets ???
Richard L 03-01-2013 07:08 PM
The calculation on the lower limit. I would increase the pump pressure by 1/2T clockwise. approximately +25psi to allow you a bit more head room. If it is too much, you can always raduce the flow with the "gain" trimmer.
dmotors 04-01-2013 03:57 PM
Ok thanks richard ill check out that
Richard L 05-01-2013 12:08 AM
Can you tell me what is your target power.
A direct port is good but I think you should consider putting one jet at the exit of the intercooler to improve you charge air cooling. I think have one medium size jet will give you that extra ceiling I was talking about. A 0.7 or 0.8 mm is about right.
It is so easy to reduce the overall flow but sizing the restrictor.
