HFS3 5A fuse blows on power up
I have a 2011 EVO X MR. I have fuse tapped the 15A cigarette lighter. Every time I place the key in the 1 position the fuse inside the HFS-3 control unit blows. I have inspected the board on the underside opposite ofguage terminal 230 may be blown out. Any thoughts? |
Re: HFS3 5A fuse blows on power up
It appeared the controller has suffered from a mis-wiring. I have seen this before when one of theb =1" v to the system is wired to ignition coil negative. The only way this can move forward is as following:
1. Return to us for repair. Gauge and Controller for. we don't charge for minor repairs 2. Check your wiring again to avoid the same problem re-occuring 3. Return shipping is ~ $39.00 Return procedure: 4. write on package "return to manufacturer for repair" will is subject to import duty 5. send to: ERL Ltd Iroko House Bolney Ave Peacehaven E. Sussex BN10 8HF England T: 01273 581007 |
