-   Aquamist HFS-4 forum (http://www.aquamist.co.uk/forum2/vbulletin/forumdisplay.php?f=48)
-   -   VW Scirocco 2.0TSI - HFS4 Work in progress (http://www.aquamist.co.uk/forum2/vbulletin/showthread.php?t=2473)
grozni 04-07-2013 11:02 AM
I'm working on finishing my system today/tomorrow. I did K04 conversion on my Scirocco, 2008 year. I will be running as Richard suggested one nozzle for now. I adjusted circuit board and jumpers per Richard schematics.. I'm sending some pictures, I will update when all is done
http://imageshack.us/a/img526/6691/jnnk.jpg
http://imageshack.us/a/img812/7043/08v5.jpg
http://imageshack.us/a/img203/840/8r10.jpg
http://imageshack.us/a/img824/9189/u3fr.jpg
http://imageshack.us/a/img19/6449/hceq.jpg
http://imageshack.us/a/img15/6701/hk8f.jpg
http://imageshack.us/a/img707/9763/9elo.jpg
http://imageshack.us/a/img829/773/eqnv.jpg
http://imageshack.us/a/img442/9933/e9ib.jpg
http://imageshack.us/a/img823/9827/mr88.jpg
http://imageshack.us/a/img6/8316/r5ai.jpg
I will put nozzle after IC. Since I have boost pressure valve on hose after IC shall I put nozzle before or after this valve? Thx a lot Richard for your help
dave80 05-07-2013 03:37 AM
Re: VW Scirocco 2.0TSI - HFS4 Work in progress
What size jet will you be running post IC.
grozni 05-07-2013 02:05 PM
I'll start from smallest I have. 0.6mm
grozni 09-07-2013 04:08 PM
What should I do with restriction?
Richard L 09-07-2013 08:08 PM
If you are only running a 0.6mm nozzle, use the smallest nozzle to keep flow linear.
grozni 10-07-2013 11:58 AM
I've updated first post with pictures on pump location and nozzle location. I had problems setting failsafe. Not sure what I was doing wrong. Here are the steps I did:
1. Priming and purging of the system
2. Test spray pattern and SC setting
3. Activate the system by F-IDC (I've changed THRES to full left, default was 12 o'clock)
4. I've returned THRES to default after I confirmed that amber led responded
Setting Failsafe:
I tried with this guide:
http://howertonengineering.com/tech-...dds3-failsafe/
1. I've changed jumper from DHB to DFS (B letter is always on)
2. Changing WH trimmer doesn't change B letter to to start flashing or to goes off (is this because of DFS jumper?)
3. Changing WL trimmer I didn't notice any difference
After this I returned WL and WH to default 12 o'clock and SC was left at 9 o'clock. Jumper returned to DHB and jumper set to DR1 instead of DR0. I tested car with these settings and I get full 8bar on full throttle. What is it that I'm doing wrong? Thx
Richard L 10-07-2013 03:34 PM
1. Running one jet requires changing the flow table (0+1) solder linked.
2. Adjust SC to read 6 bars with 0.6mm jet spray in open air
3. Set WL at 10am and WH at 2pm
With the DR1 linked. Let me know the results.
grozni 10-07-2013 04:07 PM
1. Already soldered.
2. 6 bars with jet in the air+sys jumper, or some other case?
3. Will try and let you know
DR1 is linked at the moment so I adjust SC when DR1 is linked? Do I need to link any other jumper different from factory default? Thx a lot
grozni 11-07-2013 01:40 AM
So I finished with WL between 11 and 12am (closer to 11am). Compared to 10am car goes much smoother. WH is at 2pm and SC is around 1pm (6bars reading). Richard thanks a lot for your support
Richard L 11-07-2013 08:02 AM
The WL and WH setting will be unique to your car, so they need to set individually. The bar display gives an visual indication of the "norm". Once set it should not be moved until a change of flow settings.
