Flow sensor pulse output
What is the max pulse frequency output for the turbine flow sensor? I need to know if I can wire this directly into my ECU. Thanks
Re: Flow sensor pulse output
The frequency span approximately between 10Hz to 400Hz. You need to calibrate your own flow table against frequency.
Thanks Richard
