MAP minimum treshold voltage
What is the minimum voltage from MAP-sensor (output 0-5V) to be sensed as a trigger threshold for Aquamist? (0.1V? 0.2V?)
Re: MAP minimum treshold voltage
It is:
(referring to the MPS solder link) 0.6V for A setting 1.2V for 3 setting 1.8V for 2 setting (default) |
On the other side, what is the highest voltage of the MAP sensor output voltage scale to be used as a trigger point? 4v? |
12%-72% of boost range.
A: 0.6V to 3.6V 3: 1.2V to 3.9V 2: 1.8V to 4.1V |
