Info req'd on direct porting golf 1.8t
Looking to fit direct porting to my 1.8t now strokered/ bored to 2.0lt with gt2871r turbo 630cc injectors. Want run direct port also nozzle just after my fmic to lower intake air temp. Have 200psi pump and maf operated progressive controller. What size nozzles for direct porting and size fitted after my fmic.
Thanks |
Re: Info req'd on direct porting golf 1.8t
for direct port, you'll have little choice. I use 4x 0.3mm. Depending on fuej flow you might up thesize to 4x0.4mm jets. With 630cc injectors, I'd rather use the latter.
