High speed valve
1 Attachment(s)
I have the attached on my car. I had to take this apart to remove some hose, but I'm not sure if I can refit it with new hose? It seems to be a pressure fitting, but no idea how to refit, as it does not seem to simply click into place. Was it meant to reuse a new clip every time? I realise to no longer make this part, so worst case, what part would I need to replace this with? Thanks, John |
Re: High speed valve
Is is difficult to see the hose. Unfasten the HSV and I 'll be able to give you some directions how to remove the hose from the HSV. It is most like it is jammed solid. may require a new fitting. Let's remove the hose first.
Sorry, I've maybe not explained that well. I have removed the hose already, but cannot refit. More pictures: https://goo.gl/photos/5wQvGwts8R1jYitu6 I've unscrewed the fixing from the HSV. My problem is I am not sure on how to refit the hose into the fitting. I did not want to brute force it for fear of damaging it. Thanks, John |
The fitting is damaged, you need to order this one:
http://www.aquamist-direct.com/806-3...-qty-discount/ |
Excellent, thanks a lot :D
John |
