-   -   MPS trigger issue (http://www.aquamist.co.uk/forum2/vbulletin/showthread.php?t=2819)
kenrevo 03-11-2015 04:40 AM
MPS trigger issue
I installed my system and am configuring it. When I set the trigger as MPS the THRES light instantly comes on and if I turn the gauge on both yellow lights come on and stay on. In addition the pump actives but doesn't spray when the gauge is turned on. It's configured for a 3/3.5 bar MAP since I have a 3bar sensor. I've checked the voltage on the blue wire(MPS wire) and it's ~1.65v at atmospheric. The system works fine with a IDC trigger so I think I don't have something configured right to get the MPS mode working. Am I missing something or do I have a different issue.
Thanks,
Richard L 03-11-2015 07:30 AM
Re: MPS trigger issue
Can you take a Hi-res picture of underside of the circuit board, like to check the configuration - also the serial number of the controller. send it to richard (at) aquamist.co.uk
