-   -   Water injection leaks when engine is on ?? (http://www.aquamist.co.uk/forum2/vbulletin/showthread.php?t=283)
Speed King 07-06-2004 05:31 AM
Hello I have a Motorcycle and when the Aquamist system is on and the bike is running the system leaks a few drops of water every 3-4 seconds or so, the system is new and used only one time..you can here the pump click every 1-2 seconds or so..
Any ideas?..Oh Richard where are you :twisted:
John
Richard L 07-06-2004 09:54 AM
I would like to know more details of the current problem:
1) Does the system dribble with the HSV activated or idle?
2) Does the comes out of the jet of the quickfit connectors?
3) Are the nylon hose held down on non-vibrating components.
4) Same question for the HSV
If possible, send me a few pictures for the various componets fitted.
Speed King 07-06-2004 02:31 PM
Richard even when the key is on and the bike is not running it dribbles from the hose where it attaches to the jet installed in to the boost pipe.
Number 1 yes
Number 2 ? ? dont understand?
Number 3 yes.
Number 4 again it leaks even when the bike is off and the key is on.
Richard L 07-06-2004 11:32 PM
sorry, I meant to say:
2) Does the water comes out of the jet or the quickfit connectors?
I will await for your test results of the HSVm it seemed that there is some small debris trapped on the valve seat.
Speed King 08-06-2004 01:43 AM
It runs from the JET not the hoses at the quick fittings, I will do the other things you recommened and get back with you.
Thanks again !!
John
Richard L 08-06-2004 08:35 AM
I will ask for a replacment valve send to you via one of our distributors so that you will be in good shape on Sunday's second attempt to break the current speed record.
Good luck, I will report back on the leak valve once I get it back via the post.
Speed King 08-06-2004 02:39 PM
Thanks Richard, this is about the best customer service I have seen, only thing better is if I can get you to come over and beauty of the install :mrgreen:
John
