Newbie with questions
Hello All,
Newbie here with some questions, bought a HFS-4 system and looking to install it soon. Been reading lots of threads but nothing is giving precise measurements. Here are some questions 370" LS engine Twin 67/66 turbos 90mm T/B #1 How far from the T/B should the nozzles be? There is about 15” from my I/C to my T/B. #2 When installing the dual nozzles, do you want them right across from each other or staggered in the intake tube? If staggered, how much offset distance between them? #3 Where to mount the FAV at? Close to the intake tube? |
Re: Newbie with questions
No one, has any info?.......
I'd install them right after the IC. I assume you do not have any ridges etc. in the flow path from there're that could collect droplets.
You can mount them anyway you like. It won't make a difference in this type of install as the mist goes through bends, plenum etc before entering the cylinders. I'd pay attention that you can access the jets easily for maintenance. |
