Relay clicking sound
Just finished installing a Hfs-3v.3 in my Audi A4 1.8T. When I start the car the water level light stays on even though there's enough water, decided to pull the float sensor and it got rid of the light. Now when I start it, light comes on for a few seconds, turns off and the rest of the gauge lights up. Once it hit the gas the guard lights turn off and I hear a rapid clicking sound like a relay. It does that till the RPMs go back to idle. Any suggestions?
I'll adjust the float and see if that takes car of the water light. |
Re: Relay clicking sound
Two things:
1. Check the arm of the level sensor is pointing up at 45 degrees with a full tank. 2. What wiring diagram did you use for the installation? |
Red wire to the + of the fuel injector (Black with green stripe) Used all factory grounds so they should be good too. Will check the arm today. |
This is a 20V 1.8T, you may like to swap the red and green wire of of the ECU harness to the fuel injector (+) & (-) pins. See diagram below:
http://www.aquamist.co.uk/forum/AMB.gif |
I couldn't make this any clearer with text and diagram.
you can set the Wl two clicks C-CW and let me know.
